DASYLab
what does "AI_frequency has to be changed" mean?
This error comes up when I change the sampling frequency and rate. I use 10 kHz as a sampling frequency and 6000 as a block size. Block size is the number of data that I would like to correct, right?
Thank you,
(5,775 Views)
Which module generates this message?
Look at the title bar of the message, and it should show either the name of the module or the type of module.
This message is telling you to change the "Analog Input Frequency", but it's not clear if it's the driver I/O subsystem or a different module on the worksheet.
I'm sorry that I cannot be more helpful. Our error messages can come from many sources, not just from within the software.
You've asked a bunch of questions -- if you like, send me your worksheet using a private message, so that I can review it more carefully.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,765 Views)
