DASYLab
setup value as a variable
I am trying to use the select values module with predefined positions. For the determine position, I selected the time/frequency. In predefined position value: I would like to pick up the value at the oscillating frequency for example, 200 Hz. If I put the 200 Hz in, it works fine. But, when I put the ${VAR_1} in, it doesn't work. Why?? ${VAR_1} is the input oscillating frequency that I set.
Thank you in advance,
Jane
(7,194 Views)
It works okay on my system.
What version of DASYLab do  you have?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,185 Views)
Could you post the worksheet as well?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(7,182 Views)
I have version 11. I think I've made something wrong on writing global variable (put the signal in the wrong channel).
(7,161 Views)
How are you storing your variable?
Posting your worksheet would be helpful.
(7,160 Views)
Please find below for my diagram, I am not sure is this the right way to set the variable. Thank you very much for your help,
(7,147 Views)
Could we have the DASYLab file?
In any case, how do you trigger the latch?  Also why is there a write  variable module.
If we could look at the DLab file we could help better.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
(7,137 Views)
