DASYLab
will dasylab 9 and iotech pdaq56 read a current input or just voltage and TC
I have Dasylab 9 with iotech pdaq 56 input ranges only seem to be V, mV and TC is there not a way to input mA?
(6,054 Views)
Not directly. If you add a resistor to the circuit, then V=IR will allow you to read V from I.
Please review the specifications for the device
http://www.mccdaq.com/products/pdaq50s.htm
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,053 Views)
yeah i was just browsing the website.  I bought an analyzer and requested the output changed from mA to V but the memo got lost somewhere in transit.  what kind of resistor would i need to add and where?
(6,051 Views)
DASYLab should read 1-5 volts for a 4-20mA signal – when using a 250 ohm resistor
Then use the Scaling module to scale  1V to your zero value (4ma) of the sensor, and 5 V = max value (20ma) of the sensor.
(6,034 Views)
