DATA AHEAD toolkit support Discussions
XLR8: Close Workbook inputs
I just started to use XLR8 and one question rises:
Why is the "Save (F)" input of CloseWorkbook set to required?
Or to put it the other way around: why does it have a default value when you need to wire it anyway?
(5,132 Views)
Hi GerdW,
the "save (F)" Boolean control is to ensure that the user thought about wheter he wants to save the Workbook or not! In some cases (for example after many copies with "save workbook" or many new workbooks with "create workbook") it is good to reensure the purpose of the user.
Greetings
Hajo
(4,478 Views)
Hi Hajo,
thanks for your answer, even when I don't like it…
Next question:
Is it possible to have a "Path" output from CloseWorkbook - similar to the standard LabVIEW CloseFile function?
It would help to create more "cleaned up" block diagrams…
(4,478 Views)
Hi Gerd,
sorry to hear that!
thanks for this hint!
Yes it is possible to add the workbook path output to the "CloseWorkbook" function.
Your argument about a more "cleaned up" block diagram is plausible.
We will add this to our feature list and discuss it internaly.
Greetings,
Hajo
(4,478 Views)
