DATA AHEAD toolkit support Discussions
XLR8 Error 1172 when saving
I just downloaded XLR8 through VIPM.
When I use the "Save Workbook.vi" or the "Close Workbook.vi" with the option "Save file?" at True, I have an error 1172:
I have an evaluation version (my licence is ordered 🙂). Could this explain the problem?
Thanks a lot for any help,
Pierre-Alain
(3,601 Views)
Hello Pierre-Alain,
no, it is possible to save files even with the evaluation version of XLR8.
Could you upload your VI?
DATA AHEAD
Kudos are welcome...
(3,574 Views)
Hello, thanks for the reply.
Please find here my VI. I work with a PC notebook W10, LabVIEW 2018 SP1.
(Meanwhile, I have activeted my new licence, but this didn't resolve the bug).
Thanks for any help!
Kind regards,
Pierre-Alain
(3,562 Views)
I cannot reproduce your error (especially since yours is the general .NET-error 1172), your VI is working fine with another excel file where I only renamed the first work-sheet to match your vi. Can you upload your excel-file too. It could easily be the reason for this. While the NPOI API that we use in XLR8 can handle quite a lot it is no exact replacement of Excel itself.
Can you also try your VI with this simple Excel-file.
DATA AHEAD
(3,557 Views)
Thanks!
With your Excel file, all seems to be ok.
With my file (here under), there is still an error...
Thanks again for your reactivity and support!
Pierre-Alain
(3,554 Views)
your excel file is pretty complicated and contains a lot of charts.
Unfortunately charts is something that is causing issues pretty often, which is one of the reasons why XLR8 does not provide any VIs for that.
I am also sorry to say but this is an issue which we will not tackle in the short term.
While XLR8 can do a lot it cannot and never will cover all the possibilies that Excel provides.
DATA AHEAD
(3,531 Views)
thanks for the time spent and for your honesty.
I have an application where I have to open / read and open / write a lot of Excel files. XLR8 is clearly faster compared to Report Generation Toolkit because it doesn't open Excel. It seems I can use XLR8 at least to do the read job: better than nothing but...
I see also that Report Generation Toolkit has problems too to stay compatible with office -> it is not simple whatever I use 😏
Pierre-Alain
(3,524 Views)
