In REPORT, you have the option of using a "Joint x-channel", which allows REPORT to use the x-channel of the first curve as the x-channel for all other curves in a 2D axis system.
I would like this exact same functionality in VIEW.
Hello Julia,
Thank you for your request. We closed your request because it already exist (see comment from AndreasH_Ha). In addition, we will think about how to make this (and similar) features more visible.
Greetings
Walter
