It'd be nice to be able to clear the data portal without having to go to the NAVIGATION area each time. Adding the ability to clear the data Portal from any screen, especially when scripting, would be much more convenient.
Sadie
Hi Artemis and Sadie,
DIAdem 2017 ships with a customizable icon bar for the Data Portal, plus standard "Delete INternal Data" and "Save TDM File As" icons which you can use to delete or save data sets from whatever DIAdem panel you happen to be in at that moment. Thanks for the great suggestion!
Brad Turpin
DIAdem Product Support Engineer
