Best example: If you want to test a channel for its monotony characteristics you have to write "increasing" although the property is displayed in the data portal with the value "Increasing". A very small difference that could lead to much frustration before you finally discover it (as it has in my case). So my suggestion is to simply remove the case-sensitivity for the DIAdem standard properties (not speaking of user-defined ones).
/Phex
Thank you for your suggestion. You describe a comparison of text. In VBS is this case sensitive and we have no chance to change it.
Greetings
Walter
