DIAdem has a data reduction option which can used in DIAdem Navigator to reduce the data beeing loaded but if it is up to do it after teh loading one needs to write a script or formula to do it.
I think it would be a great interest to have such a simple functionality in DIAdem Analysis too that cna be applied to the internal data (i.e. results of calculations).
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions and the fact that just a few sponsors are supporting it, we gave this request a lower priority.
Greetings
Walter
