DIAdem
2D Graph with log and linear scaling on Y-Axis
I need to plot several curves in the same graph in DIAdem 2014. I am using "n-Y Axes [Linear]", however, I need one of the curves to be scaled log while the others should be linear. Can this be done without creating a new channel that contains the log of the values I want to plot?
I can do it that way, but then the Y-Axis is somewhat hard to read, so I would prefer a log scaling on the curve
Thanks in advance for your help.
(3,871 Views)
Hi psa,
In REPORT you can configure a second Y axis and assign any curves you want to it, and you can have that second Y axis be scaled logarithmic while the first Y axis is still scaled linearly.  In VIEW there is no way to do this with an easy scaling option.
Brad Turpin
DIAdem Prodcut Support Engineer
(3,852 Views)
