DIAdem
ElementListOrABS does not support Count property
I'm using the OnDataStoreLoading event to grab some properties from loaded data, but I'm having a problem with the ElementListOrABS variable.  The variable passed to my function by the OnDataStoreLoading event is always an object, but sometimes it doesn't support the Count property.
If I load data via the Navigator Panel, it works fint, ElementListorABS.Count works as expected.  But if I load data with a script using the Navigator.LoadData command, ElementListorABS IS and object, but I get this error:
78 2:47:27 PM Error:
Incorrect instruction or user command.
In <Load_Event_OnLoading.VBS> (line: 37, column: 5):
Object doesn't support this property or method: 'ElementListOrABS.Count'
How can I check if ElementListOrABS is an object AND supports the Count property?
(4,679 Views)
Hi RussellSenior,
I tested this behavior, but could not reproduce it. I defined this user command:
Call AddUserCommandToEvent("Navigator.Events.OnDataStoreLoading","MyOnDataStoreLoading")
Sub MyOnDataStoreLoading (NaviLoadControl, ElementListOrABS, ImportAction)
  If IsObject(ElementListOrABS) Then
    Dim Element
    For Each Element in ElementListOrABS
      Call MsgBoxDisp("Element name: " & Element.Name)
  Else
    Call MsgBoxDisp("Event Parameter StorageABS" & VbCrLf & ElementListOrABS)
  End If
End Sub
and checked it interactively and with this script:
dim oLoadedData, oMySelection
set oMySelection = Navigator.Display.CurrDataStore.Browser.SelectedElements
dim oMyPropertyImportSet
set oMyPropertyImportSet = Nothing                                             ' Minimal configuration
set oLoadedData = Navigator.LoadData(oMySelection, "Load" ,oMyPropertyImportSet)     ' Use this line for DataStores without GUI
Both worked fine. I used DIAdem 2015
Greetings
Walter
(4,651 Views)
Element.Name always works for me too, it's the Element.Count property that sometimes doesn't.  If you load a single item from the MeasurmentQuantity level of a database, the Element.Count doesn't work.  If you load a Measurement level, it works fine.
I modified your code a little to reflect how I am doing this, and it's at the bottom.  Again, I get an error if I load something from the MeasurmentQuantity level. My work around is this:
On Error Resume Next
MyCount = ElementListOrABS.Count
On error goto 0
If MyCount is an empty string, I know I can't use count.
Sub MyOnDataStoreLoading (NaviLoadControl, ElementListOrABS, ImportAction) If IsObject(ElementListOrABS) Then Dim i For i = 1 to ElementListOrABS.Count Call MsgBoxDisp("Element name: " & Element(i).Name) Next Else Call MsgBoxDisp("Event Parameter StorageABS" & VbCrLf & ElementListOrABS) End If End Sub
(4,637 Views)
I used your script code and tested it with DIAdem 2015 SP1. It worked fine for TestRun, Measurement and MeasurementQantity.
Which version do you use?
Greetings
Walter
(4,633 Views)
2014 sp1.  (14.0.0f5641)
Script engine: 5.5.0.5207
(4,629 Views)
I tested it with DIAdem 2015 SP1 and 2014 SP1 - both are working fine.
Here is my test script which works with the installed ASAM test dataset and my user command.
Dim oMyConditions
Dim oMyQueryForm
'--- Search without GUI
Dim oMyDataStore, oMyQuery, oMyResults
Set oMyDataStore = Navigator.ConnectDataStore("ASAM Pass Fail Analysis Example")
Set oMyQuery = oMyDataStore.CreateQuery()
oMyQuery.ReturnType = "MeaQuantity"
Set oMyConditions = oMyQuery.Conditions
'--- Fill the query
Call oMyConditions.Add("Measurement","Test_Operator","=","George")
Call oMyConditions.Add("Measurement","Test_Status","=","Fail")
Call oMyConditions.Add("MeaQuantity","maximum",">=",50)
oMyConditions.Logic = "C1 AND C2 AND C3"
Call oMyDataStore.Search(oMyQuery)
Set oMyResults = oMyDataStore.Results
Navigator.LoadData(oMyResults)
    Dim iLoop
    For iLoop = 1 to ElementListOrABS.Count
      Call MsgBoxDisp("Element name: " & ElementListOrABS(iLoop).Name & " - " & str(iLoop) & " of " & ElementListOrABS.Count)
  Else
  End If
End Sub
Please could you test it with these scripts?
Greetings
Walter
(4,603 Views)
