DIAdem
2D X axis Scaling on Reports
HI,
My time data comes in using the system time from the computer and does not start at zero.  It is often starting at 3000 sec or 6240 sec, etc..
When I run my report I am constantly having to change the beginning and end times in order to capture the data.  I came up with a partial solution to my problem, but am still running into one issue.  Some of the report pages have 2 2Dgraphs on them, and others only have 1 2Dgraph.  With the solution I have found, I can change all the report pages that have 2 graphs, but as soon as I hit one that only has 1 graph it throws an error.  I'm sure that there is an IF statement I can use, but have been unable to get one to really work.
I have tried using ObjectNoMax and I have tried using "2DAxis1" instead of ("Area : 1"), but I still can't figure it out.  Can someone please help?
Dim intSheetNo
Call GraphSheetInfos() 'Puts the number of sheets in GraphSheetCount
 For intSheetNo = 4 To GraphSheetCount
   CallGraphSheetNGet(intSheetNo) 'Puts the sheet name in GraphSheetName
   CallGraphSheetShow(GraphSheetName) 'Shows the sheet in DIAdem REPORT
   CallGraphObjOpen("Area : 1")
   CallGraphObjOpen("Area : 1_XAxis1")
    D2AxisXBegin = ChnValMin(35)
    D2AxisXEnd = ChnValMax(35)
    D2AxisXOrigin = ChnValMin(35)
   CallGraphObjClose("Area : 1_XAxis1")
   CallGraphObjClose("Area : 1")
   CallGraphObjOpen("Area : 2")
   CallGraphObjOpen("Area : 2_XAxis1")
      CallGraphObjClose("Area : 2_XAxis1")
      CallGraphObjClose("Area : 2")
Call PicUpdate(0) '... PicDoubleBuffer
(6,677 Views)
Hi 2Pale,
Let's start by seeing if the object name is the problem.  Try this approach with ReportObj(n) to programmatically use the nth object's name with the rest of you existing code unchanged:
  FOR n = 1 TO ObjectNoMax
    IF ReportObj(n) = "" THEN Exit For ' n
    Call GraphObjOpen(ReportObj(n))
Call GraphObjClose(ReportObj(n))
NEXT ' n
Brad Turpin
(6,658 Views)
Hi 2Pale,
I just noticed that you are looping through REPORT sheets.  Make sure you use the GraphSheetRefSet() command to set the currently visible sheet to be the one addressed by all the Graph...() commands.  It's possible that your commands have been operating on other REPORT sheets than you have intented.
  Call GraphSheetNGet(GraphSheetCount)
  Call GraphSheetShow(GraphSheetName)
  Call GraphSheetRefSet(GraphSheetName)
Note, this got MUCH easier in DIAdem 2012 with the new Report object.
Brad Turpin
(6,657 Views)
With this method, how do I open the 2D-Axis so that I can adjust the D2AxisXBegin?
If I leave the GraphObjOpen("Area : 1_Xaxis1") it only adjusts one graph per page and not both.
If I leave it out there is an error.
Anything else I have tried as the GraphObjectName just doesn't seem to work.
(6,617 Views)
Tried the following -
 99      Dim intSheetNo, n
100     Call GraphSheetInfos()                'Puts the number of sheets in GraphSheetCount
101     For intSheetNo = 4 To GraphSheetCount
102     Call GraphSheetNGet(intSheetNo)     'Puts the sheet name in GraphSheetName
103     Call GraphSheetShow(GraphSheetName) 'Shows the sheet in DIAdem REPORT
104     Call GraphSheetRefSet(GraphSheetName)
105
106      FOR n = 1 TO ObjectNoMax
107     IF ReportObj(n) = "" THEN Exit For'
108
109    Call GraphObjOpen(ReportObj(n))
110    Call GraphObjOpen(D2AxisXObj(n))
111    D2AxisXBegin        = ChnValMin(35)
112    D2AxisXEnd          = ChnValMax(35)
113    D2AxisXOrigin       = ChnValMin(35)
114    Call GraphObjClose(D2AxisXObj(n))
115
116    Call GraphObjClose(ReportObj(n))
117    NEXT 'n
118    Next
119
120     Call PicUpdate(0)                       '... PicDoubleBuffer
When I got to sheet 8 of my report there was an error.  (That is the first page with only 1 graph on it)  "Empty string not valid as object name" for line 110.
***Looked at this closer - it did not change any of my xaxis begin and end points either" ****
So I tried adding a line after 107:
108    If D2AxisXObj (n) = "" Then Exit For
and now error is "Invalid variable access (D2AxisObj), Parent Object open?"
(6,612 Views)
Accepted by 2Pale4TX
Success!!!  I finally got it to work.
Dim intSheetNo, n, p
p=reportobj(n)
    Call GraphObjOpen(p)
call graphobjopen(D2AxisXObj(1))
call graphobjclose(D2AxisXObj(1))
    Call GraphObjClose(p)
   NEXT 'n
(6,603 Views)
