DIAdem
2D checker-board display
I've been trying to find a way to display 2-D data in a checkerboard display format. For instance I wish to display a X-Y two dimensional matrix that has an integer in each X-Y location indicating the checkerboard colour. Similar to the picture graph functionality in Labview.
(2,987 Views)
To clarify, this display is for a report layout.
(2,917 Views)
Accepted by Bilby42
Hi Bilby,
Here's the recipe.
1)  Select the 3D Surface type "2D matrix"
2)  In the "2D matrix" configuration dialog, set the X and Y widths to 0
3)  Set the "2D matrix" color to "Glob. Palette 1"
4)  Set the 3D rotation angles to show the XY plane from straight above
5)  Use XYZZZZZ (matrix) formatted data, not XYZ (triplet) data
Brad Turpin
DIAdem Product support Engineer
(2,894 Views)
