DIAdem
2dY-Axis
i want to create a second y-Axis in a 2D-Axis system. I'd tried the following code:
Call GraphObjNew("2D-YAxis","Name")
The Error Message: The objecttype 2D-YAxis is not known.
The TeachIn function do not recognize the creation of an secondary axis and the online help have no helpful entry to this topic.
Greetinx Micha
(4,095 Views)
Hello MichDD,
Concerning that question, please contact me: walter.rick@ni.com
Greetings
Walter
(4,070 Views)
is there a fix for this yet (DiaDEM 10.1)?
Ton
My LabVIEW Ideas
(3,919 Views)
Hi TonP,
Yes there is.
Greetings Walter
Command: GraphObjYAxisNew
Creates a new y-axis.
ReturnValue = GraphObjYAxisNew(YAxisAlignment)
Input Parameters
YAxisAlignment Specifies on which side DIAdem creates a new axis.
Return Parameters
ReturnValue The return value is an Integer variable type. Specifies the number of the subaxis. If the value is null, DIAdem was not able to generate a subaxis.
The following example generates a new y-axis and labels the y-axis.
Dim AxisNo
Call GraphObjOpen("2D-Axis1")
AxisNo = GraphObjYAxisNew("left")
If AxisNo>0 Then
Call GraphObjOpen(D2AxisYObj(AxisNo))
D2AXISYTXT ="My new axis"
D2AXISYTXTFONT ="Arial"
D2AXISYTXTCOLOR ="red"
Call GraphObjClose(D2AxisYObj(AxisNo))
End If
Call GraphObjClose("2D-Axis1")
(3,912 Views)
