DIAdem
Importing Graphics in DIAdem
I am creating reports in diadem and have a problem with the quality of the graphics files I import into DIAdem. No matter how "god" i make them I still get fuzzy edges when looking at the graphics in DIAdem and after exports to pdf.
I have tried .eps files .high quality .jpg .bmp and .wmf. Any suggestions?
Ståle
(4,227 Views)
Hi Sped,
what DIAdem Version are you using?
It would be cool if you just attach a picture, that I can see what you are working with.
Greetings,
Stefan Henke
NIG
(4,208 Views)
I am using DIAdem 9.1 and cannot upgrade based on linking with other applications.
( I do not have a host server for the pictures...) Usually when I add a file to a reporting tool espcially .eps they take into consideration the size of the original file. DIAdem sets up the file much smaller than the original size. Looking at the example logoes of NI the same is true opening the library file in a picture editor gives you a picture 10 times larger than in DIAdem.
(4,200 Views)
Hi again,
I am sorry, I did add several pictures to the report in DIAdem 9.1 and did an exort to pdf. I allways get a good quality.
It would help alot, if you are able to send a picture and a TDR file, so that I am able to reproduce the problem.
Greetings,
Stefan Henke
NIG
(4,195 Views)
Hi again,
Greetings,
Stefan Henke
NIG
(4,195 Views)
Hi sped,
If sending the picture files doesn't work, please try to create a picture using PNG as file format and let us know how it works.
Andreas
(4,181 Views)
