DIAdem
3D Axis System (bar type) doesn't work when there is only one z-channel
I have a problem with a 3D Axis System, bar type.
Everything works fine as long as the y-channel contains more than one value (meaning there is more than one z-channel too).
But when my y-channel has only one value, and there is only one z-channel, the axis system goes blank (there is just an empty white field with a thin outline).
I don't understand why it doesn't work that way. The length of my one z-channel is the same length as my x-channel, as it should be.
(5,264 Views)
HI,
could you describe your hardware and software setup?
If this is possible please attache your project.
Roman Rolnik
Application Engineer
NI Germany
(5,247 Views)
Hi maliya,
Would you please submit this small data set and your *.TDR file that contains the REPORT configuration you're using?
Brad Turpin
DIAdem Product Support Engineer
(5,238 Views)
I can't submit the exact data I was working with but here's a small example that illustrates the problem (data and report file).
(5,226 Views)
Hi Maliya,
you need at least 2 values in each axis to show it in a 3D Axis System.
Best regards
Roman Rolnik
NI Germany
(5,215 Views)
