DIAdem
3D Characteristic diagram color shading in script
In the 3D Characteristic diagram: curve parameters under the Surface tab in layout there is a choice of color shading or Colors from Contour table. Which properties do I use to set this in Diadem script?
(4,720 Views)
Hi FrankHS,
So the way to get the properties of a particular dialog box in DIAdem is a little odd. I will walk through them here:
1. First make sure your SCRIPT is in recoding mode.
2. Then navigate to your plot with the curve you would like the parameters of.
3. Navigate to the correct dialog box, and do Ctrl+Shift+C.
4. Go to the SCRIPT pane and stop recording.
This will paste the properties from the dialog box into your SCRIPT and you can change the values programmatically.
Rachel M.
(4,694 Views)
