DIAdem
AVL IFILE --> Engine parameters not imported?
after reading an IFILE using the corresponding AVL_IFILE DataPlugin I have noticed that the engine parameters (bore, stroke, compression, etc.) were not imported.
Is there any chance to directly import the engine parameters using this AVL_IFILE DataPlugin?
Thanks for replying
(5,712 Views)
Hello delux
You can contact the developers using this email:
dataplugins@ni.com
If the parameters were not imported properly, maybe the pluging needs to be modified
Warm regards
Mart G
(5,651 Views)
