DIAdem
Text in Combo Box used in Report
I want to use in my Report, the text of the index selected in the combobox. Unfortunately, the variable for a ComboBox is L1, not as text T1. So when I want to insert Text in the Report I cannot write @L1@ because it appears the index, not the text.
For example
ComboBox1
0.red 1.green 2.yellow
and If I choose 1. green
I want to post "green" as text in my Report. I cannot call as a variable because the variable L1 is not text.
How can I do this?? Please 🙂
(5,976 Views)
Hello andrea11hr
Please find attached an example which explains how to exchange information between Script and SUD:
(5,962 Views)
Thank you Walter, the example helped me.Now I have another issue...
For instance, if I don´t have one but an array of inserted values in the EditBox, how would you transfer them to the script DIAdem environment, I tried adding the values I inserted in the text box into a channel using CHT() from the dialog box script but it says it is not authorized.
Thank you again!
(5,946 Views)
Accepted by topic author andrea11hr
Hi andrea11hr,
You can use an array for the info exchange. Please have a look at the attached example
Greetings
Walter
(5,941 Views)
Thank you very much . I will use an array as an argument 🙂
(5,938 Views)
