DIAdem
Accessing an Array/Vector by field name
Hey gents,
I was wondering if there is any way to create and then access to the pieces of the arrays/vectors by field names instead of by position.
That's what I mean, could I create something similar like this;
          Dim MyFriend
                 MyFriend=(name="mike",last="Miller"....)
'  and then access by name
                someone=MyFriend(name)
I'm working with some large arrays and therefore is hard to remember which field is in which position
Thanks!!
Javier
(5,243 Views)
Hi Javier,
I’m not sure whether I understand you correct – so I assume with “array/vector” you meant a channel in DIAdem. If so, you have the DATA-API in DIAdem since several years. Here are some examples (based on the dataset “Example_Data.TDM” which is installed with DIAdem):
Dim oMyFriend
set oMyFriend = Data.GetChannel("[1]/Speed")
msgbox oMyFriend.Size
' or
Dim oMyListOfFriends
set oMyListOfFriends = Data.CreateElementList
oMyListOfFriends.Add(oMyFriend)
oMyListOfFriends.Add(Data.GetChannel("[1]/Torque"))
msgbox oMyListOfFriends(1).Name
msgbox oMyListOfFriends(oMyListOfFriends.Count).Name
Do you mean those things?
Greetings
Walter
(5,232 Views)
There is a dicitionary object that can be used for lookups
Set Dict = CreateObject("Scripting.Dictionary")
Call Dict.Add("Mike", "Miller")
IF Dict.Exists("Mike") THEN
  dim someone : someone = dict.Item("Mike")
end if
 Compare can be set to text compare. Check dictionary in the DIAdem help.
The second argument can also be a class object which is assigned by use of "set".
(5,231 Views)
Accepted by topic author Tafalla
Hey AndreasK, thanks!!,
The "dictionary" was exactly what I meant, an "associative array". This solves my "problem"!! I used to work with similar sintax in other languages and working w/o it was being painful!!!
Walter_Rick thanks also for answering!!!
Javier
(5,215 Views)
