DIAdem
script manager syntax error
I am trying to use the DIadem calculation manager but I face a problem with the syntax. Here enclosed is my script, input and output channels as well as the error that I get.
Thank you for your support
Best regards
Jérémy
(5,005 Views)
Hi Jérémy,
The error you talk about could refer to a name redefined error which is thrown when two variables of the same name are declared. Running a script with with two variables of the same names will give an error message similar to yours.
Could you verify this point so ?
Also, if not, could you zip your diadem project to test it ?
(4,978 Views)
