DIAdem
Add ElementList entry from DataFileLoad
If I run the following two commands:
Dim oMyList : Set oMyList = Data.CreateElementList
Call oMyList.Add(DataFileLoad("C:\Program Files (x86)\National Instruments\DIAdem 2012\Examples\Data\Example_data.TDM", "TDM", "Load"))
 with the Run Script button I get that error message:
"The DataElement argument of the Add method must be Element<Data>."
Running it as Debug/Continue Script, it works perfectly.
Why?
(5,487 Views)
The helps says, that Add only acceps a single elment.
dim elems : set elems = DataFileLoad("C:\Program Files (x86)\National Instruments\DIAdem 2012\Examples\Data\Example_data.TDM", "TDM", "Load")
dim elem : for each elem in elems
  Call oMyList.Add(elem)
next
 should work. On my machine DIAdem 2012 your code fails in each mode.
(5,476 Views)
Strange that the code fails on your machine but not on mine.
Nevertheless I meanwhile applied the same solution you suggested, athough in my specific case it is only a single ChannelGroup that is being loaded into the DataPortal each time. As the ReturnValue of DataFileLoad then contains only one element of type ChannelGroup, I supposed that the Add method works directly, but it doesn't.
(5,471 Views)
