DIAdem
How to call a vbs script from another vbs script?
Hi All,
        I have written multiple vbs scripts to perform different sub tasks. Now I want to combine them into one single script (which will call other vbs scripts in turns) so that the complete sequence is automated. I tried Call Script1, Call Script1()Script1() etc. But these syntaxes did not work. Kindly let me know how I can call other vbs scripts from a vbs script?
With warm regards,
Saurav
(35,928 Views)
The following worked for me....
Call ScriptStart(autoactpath & "MYSCRIPT.VBS")
BBANACKI
(35,925 Views)
Thanks for the help...
(35,894 Views)
Hi Murherjee,
The ScriptStart() function is an excellent way to call another VBScript when you don't need to pass it any parameters.  For the case that you want to pass variables to an external function in another VBScript, I'd recommend the ScriptInclude() command.
Brad Turpin
DIAdem Product Support Engineer
(35,878 Views)
Thanks Brad, this also helped me out!  And, funny seeing you here...
(11,644 Views)
