DIAdem
Adding Multiple Channel references in Diadem Report
Hi All,
I'm currently working on a report generation for my project(Amplifier Testing). I want to plot multiple channels in a single plot in a Diadem Report by vb scripting. ie, I have actual voltage channel data, Upper tolerance, lower tolerance etc. I want all these channels to be plotted in a single graph in Diadem Report. I have used below statements.
Set oMy2DCurve1 = oMy2DaxisSystem.Curves2D.Add(e2DShapeLine, "MyNew2DCurve")
oMy2DCurve1.Shape.XChannel.Reference = "[1]/[30]"
oMy2DCurve1.Shape.YChannel.Reference = "[1]/[11]"
In VIEW tab, I'm able to do this by repeating below statements.
Set oMyChart = View.ActiveSheet.ActiveArea.DisplayObj
Set oMyCurve = oMyChart.Curves2D.Add("[1]/[28]","[1]/[13]")
Set oMyCurve = oMyChart.Curves2D.Add("[1]/[28]","[1]/[15]")
Set oMyCurve = oMyChart.Curves2D.Add("[1]/[28]","[1]/[17]")
I believe, we can add only one Y channel reference in Graph in Diadem Report. Is there any workaround for this?
Certified LabVIEW Architect
System Test Architect
Electrical Engineering
JLR
(2,004 Views)
Hi Rishi,
You can programmatically add up to 250 curves in a REPORT graph (last I checked), and each curve can have an Xchannel and a Ychannel or just a Ychannel, as you wish.  Here's an example of what I think you're describing.
' Loading data set and REPORT layout to match your scenario
DataFilePath = "C:\Users\Public\Documents\National Instruments\DIAdem 2020\Data\Example.tdm"
Call Data.Root.Clear()
Call DataFileLoad(DataFilePath, "TDM")
LayoutFilePath = "C:\Program Files\National Instruments\DIAdem 2021\Libr\Documents\EXAMPLE.TDR"
Call Report.LoadLayout(LayoutFilePath)
' Adding all the channels in the 1st Group as curves
Set Channels = Data.Root.ChannelGroups(1).Channels
Set Sheet = Report.ActiveSheet
Set Graph = Sheet.Objects("2DAxis1")
Call Graph.Curves2D.RemoveAll()
jMax = Channels.Count
ReDim Curves(jMax-1)
FOR j = 1 TO jMax-1
  Set Curves(j) = Graph.Curves2D.Add(e2DShapeLine, "Curve" & j)
  Curves(j).Shape.XChannel.Reference = Channels(1).GetReference(eReferenceIndexName)
  Curves(j).Shape.YChannel.Reference = Channels(j+1).GetReference(eReferenceIndexName)
NEXT ' j
Call Report.Refresh()
Brad Turpin
Principal Technical Support Engineer
NI
(1,931 Views)
