DIAdem
Programmatically hide & disable DIAdem panel bar buttons
How can I in a script hide and disable DIAdem panel bar buttons.  I can access the menu, toolbar, and group bar items, but not the panel bar buttons.   See attached visual reference.
(2,235 Views)
Hi Mark,
I can show you how to remove, reinstate and also hide the main panel items, but I don't see a mechanism to set one to disabled.  Here's how you hide a panel icon:
Set ActivePanels = BarManager.Bars("DIAPanels").UsedActionObjs
Set VisPanel = ActivePanels("DIAPanelVISUAL")
VisPanel.Visible = False
Call WndShow("SHELL")
Here's how you remove a panel:
Call ActivePanels.Remove("DIAPanelNAVIGATOR")
Call ActivePanels.Remove("DIAPanelVIEW")
Call ActivePanels.Remove("DIAPanelANALYSIS")
Call ActivePanels.Remove("DIAPanelREPORT")
Call ActivePanels.Remove("DIAPanelDAC")
Call ActivePanels.Remove("DIAPanelVISUAL")
Call ActivePanels.Remove("DIAPanelSCRIPT")
Here's how you reinstate the icons that you've removed:
IF ActivePanels.Exists("DIAPanelNAVIGATOR") THEN Call ActivePanels.Remove("DIAPanelNAVIGATOR")
IF ActivePanels.Exists("DIAPanelVIEW")      THEN Call ActivePanels.Remove("DIAPanelVIEW")
IF ActivePanels.Exists("DIAPanelANALYSIS")  THEN Call ActivePanels.Remove("DIAPanelANALYSIS")
IF ActivePanels.Exists("DIAPanelREPORT")    THEN Call ActivePanels.Remove("DIAPanelREPORT")
IF ActivePanels.Exists("DIAPanelDAC")       THEN Call ActivePanels.Remove("DIAPanelDAC")
IF ActivePanels.Exists("DIAPanelVISUAL")    THEN Call ActivePanels.Remove("DIAPanelVISUAL")
IF ActivePanels.Exists("DIAPanelSCRIPT")    THEN Call ActivePanels.Remove("DIAPanelSCRIPT")
IF ActivePanels.Exists("NewPanel")          THEN Call ActivePanels.Remove("NewPanel")
IF NOT ActivePanels.Exists("DIAPanelNAVIGATOR") THEN Call ActivePanels.Add("DIAPanelNAVIGATOR")
IF NOT ActivePanels.Exists("DIAPanelVIEW")      THEN Call ActivePanels.Add("DIAPanelVIEW")
IF NOT ActivePanels.Exists("DIAPanelANALYSIS")  THEN Call ActivePanels.Add("DIAPanelANALYSIS")
IF NOT ActivePanels.Exists("DIAPanelREPORT")    THEN Call ActivePanels.Add("DIAPanelREPORT")
IF NOT ActivePanels.Exists("DIAPanelDAC")       THEN Call ActivePanels.Add("DIAPanelDAC")
IF NOT ActivePanels.Exists("DIAPanelVISUAL")    THEN Call ActivePanels.Add("DIAPanelVISUAL")
IF NOT ActivePanels.Exists("DIAPanelSCRIPT")    THEN Call ActivePanels.Add("DIAPanelSCRIPT")
IF ActivePanels.Exists("DIAPanelNAVIGATOR") THEN Call ActivePanels("DIAPanelNAVIGATOR").Reset
IF ActivePanels.Exists("DIAPanelVIEW")      THEN Call ActivePanels("DIAPanelVIEW").Reset
IF ActivePanels.Exists("DIAPanelANALYSIS")  THEN Call ActivePanels("DIAPanelANALYSIS").Reset
IF ActivePanels.Exists("DIAPanelREPORT")    THEN Call ActivePanels("DIAPanelREPORT").Reset
IF ActivePanels.Exists("DIAPanelDAC")       THEN Call ActivePanels("DIAPanelDAC").Reset
IF ActivePanels.Exists("DIAPanelVISUAL")    THEN Call ActivePanels("DIAPanelVISUAL").Reset
IF ActivePanels.Exists("DIAPanelSCRIPT")    THEN Call ActivePanels("DIAPanelSCRIPT").Reset
Brad Turpin
Principal Technical Support Engineer
NI
(2,201 Views)
Don't forget the ever handy BarManager.Reset
(2,196 Views)
All worked perfectly.  Thank you for the helpful example code.
(2,148 Views)
