DIAdem
Adding TDMS File properties with C API
I'm using the free C API (dll) to write TDMS files. Everything works perfect except the following function call.
int __stdcall DDC_CreateFilePropertyString (DDCFileHandle file,
			const char *property,
		                const char *value);
 I call the following function in advance to create the TDMS file.
int __stdcall DDC_CreateFile (const char *filePath,
			const char *fileType,
			const char *name,
			const char *description,
			const char *title,
			const char *author,
		         DDCFileHandle *file);
 When i call the function to create the property it returns with the error code -6202 (invalid argument). I don't think there is an invalid argument in my call. Does anyone have some example code? Do I have to do something before i can create a property?
Thanks for your help.
(6,007 Views)
Accepted by DevKev
Does
DDC_CreateFilePropertyString (file, "MyProperty", "MyValue");
 work?
(5,999 Views)
I just tried that (i'm sure i tried it before but with different values) and it worked. I'm very confused. I alwys tried it with "Test Property" and "Test Value". I figured out that its not possible to have the word "property" in your property name. It works if you don't use a space in between. Weired but true. Thanks a lot.
(5,964 Views)
Hi DevKev,
The only allowable characters in a property name are the letters "A - Z" the numbers "0 - 9" and the underscore character ("_"), and the property name can not start with a number.  These limitations make everything easier in the DataFinder data base and the underlying SQL queries that you send to it with DIAdem or LabVIEW.
Brad Turpin
(5,945 Views)
