DIAdem
Adding TDMS File properties with C API
I'm using the free C API (dll) to write TDMS files. Everything works perfect except the following function call.
int __stdcall DDC_CreateFilePropertyString (DDCFileHandle file,
			const char *property,
		                const char *value);
 I call the following function in advance to create the TDMS file.
int __stdcall DDC_CreateFile (const char *filePath,
			const char *fileType,
			const char *name,
			const char *description,
			const char *title,
			const char *author,
		         DDCFileHandle *file);
 When i call the function to create the property it returns with the error code -6202 (invalid argument). I don't think there is an invalid argument in my call. Does anyone have some example code? Do I have to do something before i can create a property?
Thanks for your help.
(6,004 Views)
Accepted by topic author DevKev
Does
DDC_CreateFilePropertyString (file, "MyProperty", "MyValue");
 work?
(5,996 Views)
I just tried that (i'm sure i tried it before but with different values) and it worked. I'm very confused. I alwys tried it with "Test Property" and "Test Value". I figured out that its not possible to have the word "property" in your property name. It works if you don't use a space in between. Weired but true. Thanks a lot.
(5,961 Views)
Hi DevKev,
The only allowable characters in a property name are the letters "A - Z" the numbers "0 - 9" and the underscore character ("_"), and the property name can not start with a number.  These limitations make everything easier in the DataFinder data base and the underlying SQL queries that you send to it with DIAdem or LabVIEW.
Brad Turpin
DIAdem Product Support Engineer
(5,942 Views)
