DIAdem
Adding picture files into a diadem report makes large pdfs
When I add a 2,5MB picture file into a Diadem report and export it as pdf, the file size of the pdf gets almost 26MB. Why is that?
Pellep
(3,576 Views)
Hi Pellep,
That does sound like a disproportionate size jump.  Possibly the difference is in the picture quality used to store the PDF file.  If you use a very high PDF pictiure resolution to store a lower resolution picture, the resulting PDF file will certainly be larger by some factor.  If you are using DIAdem 11.0 or later, you can programmatically set the PDF resolution-- here are the possible settings:
PDFResolution = "Default"
PDFResolution = "72 DPI"
PDFResolution = "150 DPI"
PDFResolution = "300 DPI"
PDFResolution = "600 DPI"
PDFResolution = "1200 DPI"
PDFResolution = "2400 DPI"
If you're using a version of DIAdem prior to 11.0, you can still affect this setting in the printer setup of the "DIAdem PDF Printer" in "Start Menu >> Settings >> Printers and Faxes"
Brad Turpin
DIAdem Product Support Engineer
(3,567 Views)
