DIAdem
Rainflow modification....
Hello... bit of a longer one this.
I've used the script kindly posted by ChristianW ages back, and modified it to go through a mass of channels and create a group for each one, then do a rainflow analysis, and create a range-mean matrix. It works fine on the first channel, and then puts in 0 for all the other channel's matrices.
The original script is here...
http://forums.ni.com/ni/board/message?board.id=60&message.id=6159
Then my modified version is as below....
Any thoughts?
Thankyou!!!!!!
Tom
Option Explicit
sub ConvertFromTo2RangeMean(ChX,ChY,ChZ,x)'original subroutine
  Dim clx, cly, clz, bError, i, j, Delta, myValue, xi, yi, oldValue
  Call GroupDefaultSet(x)         ' I added this line in to make sure we stay in the right group... made no other changes within the subroutine, all the other changes are at the main program at the bottom
  if (ChX<=0) or (ChY<=0) or (ChZ<=0) then
    exit sub
  end if
  clx=Cl(ChX) 'From
  cly=Cl(ChY) 'To
  if (clx<2) or (cly<2) or (clx<>cly) then
    exit sub
  end if
  bError=false
  for i=0 to clx-1
    clz=cl(ChZ+i)
    if clz<>clx then
      bError=true
    end if
  next
  if bError then
    exit sub
  end if
  'create range vector
  Delta= ChD(2,ChX)-ChD(1,ChX)
  call ChnAlloc("Range",clx)
  for i=1 to clx
    ChD(i,"Range")= (i-1)*Delta
  next
  'create mean vector
  call ChnAlloc("Mean",cly)
  for i=1 to cly
    ChD(i,"Mean")= chd(i,chx)
  next
  'create matrix
  for i=1 to clx
    call ChnAlloc("Z"&i,clx)
    cl("Z"&i)=clx
  next
  'initialize matrix
  for i=1 to clx
    for j=1 to cly
      Chd(i,"Z"&j)=0
    next
  next
  for i=1 to clx
    for j=1 to cly
      if i<>j then 'No countings on the diagonal
        myValue = Chd(i,ChZ+j-1)
        if myValue<>0 then 'Any counting?
          xi=abs(j-i)+1             'Range
          yi=round(abs(j+i)/2+0.49) 'Mean (will be counted class wise ==> mean 3.5 is in class 4)
          oldValue = Chd(xi,"Z"&yi)
          Chd(xi,"Z"&yi)=oldValue+myValue
        end if
      end if
    next
  next
end sub
' Modification to script....
Dim x
dim j
Dim nameofgroup
Dim nGlobUsedChn
for x=2 to 5
'GroupChnCount(1)
  Call GroupDefaultSet(1)
  nameofgroup=ChnName(x)
  Call GroupCreate(nameofgroup,x)     '... GroupCreateName,TargetGroupIndex                '... TargetGroupIndex
  Call ChnClpCopy("[1]/["&x&"]")    '... ClpSource
  Call ChnClpPaste(ChnNoMax+1)                   '... ClpTarget
  Call GroupDefaultSet(x)   'make sure we are deleting the right channels
  nGlobUsedChn = GlobUsedChn
'  ClassMeth2       ="Automatic"
'  ClassNo          =30
'  RainResiduumCalc =0
'  RainFrequencyTyp ="Cumulative"
'  RainChnContain   ="Class mean"
'  Hysteresis       =0
'  RainMatTrans(1)  =0
'  RainMatTrans(2)  =1
'  RainOneParaCalc(1)=0
'  RainOneParaCalc(2)=0
'  RainOneParaCalc(3)=0
'  RainOneParaCalc(4)=0
'  RainSpecOnePara(1)=0
'  RainSpecOnePara(2)=0
'  RainSpecOnePara(3)=0
'  RainSpecOnePara(4)=0
  Call ChnRainCalc(ChnNoMax,"Automatic",0,0,"Cumulative") '... Y,ClassMeth2,RainResiduumCalc,Hysteresis,FrequencyPara
  Call ConvertFromTo2RangeMean(nGlobUsedChn+1,nGlobUsedChn+3,nGlobUsedChn+3,x)
  'delete excess channels
'  Call GroupDefaultSet(x)   'make sure we are deleting the right channels
'  Call ChnDelete("ResidueStartClasses")
'  Call ChnDelete("ResidueTargetClasses")
'  Call ChnDelete("RainflowMatrixX")
'  Call ChnDelete("RainflowMatrixY")
'  for j = 1 to ClassNo
'    Call ChnDelete("RainflowMatrixZ"&j)
'  next
nGlobUsedChn = 0
next
(4,872 Views)
Accepted by topic author xxxtomxxx
Aha, solved it.
The problem was that multiple channels had the same name, so now I'm specifying a new name each time the subroutineruns.
Tom
(4,847 Views)
Hello Tom,
this modification of your script should run:
Option Explicit
exit sub
end if
clx=Cl(ChX) 'From
cly=Cl(ChY) 'To
exit sub
end if
bError=false
for i=0 to clx-1
clz=cl(ChZ+i)
if clz<>clx then
bError=true
end if
next
if bError then
exit sub
end if
for i=1 to clx
ChD(i,"/Range")= (i-1)*Delta
next
'create mean vector
for i=1 to cly
ChD(i,"/Mean")= chd(i,chx)
next
'create matrix
for i=1 to clx
cl("/Z"&i)=clx
next
'initialize matrix
for i=1 to clx
for j=1 to cly
Chd(i,"/Z"&j)=0
next
next
for i=1 to clx
for j=1 to cly
oldValue = Chd(xi,"/Z"&yi)
Chd(xi,"/Z"&yi)=oldValue+myValue
end if
end if
next
next
end sub
Dim x
dim j
Dim nameofgroup
Dim nGlobUsedChn
for x=2 to 5
'GroupChnCount(1)
ClassNo =30
' Hysteresis =0
RainMatTrans(1) =0
RainMatTrans(2) =1
Call ConvertFromTo2RangeMean(nGlobUsedChn+1,nGlobUsedChn+2,nGlobUsedChn+3,x)
' next
nGlobUsedChn = 0
next
The changes I made are in detail:
  1. In ConvertFromTo2RangeMean I changed references via channel name from "name" to "/name". This ensures referring the channel "name" in the default group instead of the first channel "name" in all channels.
  2. All global parameters (e.g. ClassNo, RainMatTrans(2)) must be set before running ChnRainCalc.
  3. ConvertFromTo2RangeMean must be called with the first, second and third result channel of ChnRainCalc.
Christian
(4,841 Views)
