DIAdem
Align multiple Y-axis 0-level?
Hi, is there a way to align all my Y-axis automatically in DIAdem 2012 without any scripts?
I have tried to search all settings in DIAdem but not found anything that works.
Looking at the graph below, I would like all the Y-axis to have their 0-value at the same position (red line).
Thanks in advance!
/Mikael
(1,376 Views)
You didn't say if that image is from the View panel, or Report panel. You cannot do what you ask in the View panel because it is to be used for interactive graphical analysis of channels, but you can in the Report panel.
In Report, select the 2D chart and right click and choose 'Settings' (or double click on the 2D chart).  Choose the 'Axis Parameters' tab. Select the Y1 axis, and then  change the 'Scaling Mode' to manual.
(1,315 Views)
