DIAdem
Any way to load TDM-files into external programs?
I cant use excel because the data I am saving is very very large.  right now I'm looking into 650MB.
I would rather use labview to view the data, but because of this large size, when I read it back, labview says it ran out of memory.  The only option i have right now is IGOR unless I can get labview to display the information.  Any Ideas why Labview runs out of memory?
Travis
Message 11 of 12
(1,202 Views)
Hi Travis,
That's a pretty big file.  LabVIEW could easily read in sections (time windows) of that TDM file, if you are mainly interested in looking at/working with part of the data at a time.  If you really need the whole array in memory all at once, then LabVIEW may indeed struggle.  How does Igor handle data files approaching a GigaByte?  Have you tried this before?
I know for a fact that DIAdem is quite comfortable with data sets that large and has a number of clever ways of handling data sets that are bigger than your available RAM or even bigger than the memory that the Operating System is willing to give it.  I can appreciate that you're interested in establishing a process that you can use moving forward, and it sounds like you already own Igor (or is it freeware?), but I'm going to repeat my suggestion that you download a 30 day evaluation version of DIAdem and give it a try:
https://sine.ni.com/apps/utf8/nigb.guestbook?code=GB_EVALDIADEM81&lang=US&gb_prof_id=1889&scode=&pr=...
DIAdem will automatically be able to read your TDM files, and if you right-click on the file and select "Register Data", DIAdem will cleverly use the data file as in-place virtual memory that DIAdem manages, avoiding the laborious process of copying the whole data file to the OS page file and relying on the OS to manage virtual memory for it (with a 32 bit OS limit of 2 GB per application).
Brad Turpin
DIAdem Product Support Engineer
Message 12 of 12
(1,186 Views)
