DIAdem
Append view layouts/worksheets with automatic increase of link to datasets in the DataPortal - DIAdem VIEW
Hello Brad,
The append script for the VIEW and REPORT are used by me and my colleagues very often. Thanks a lot for that!
Is it possible to extend the script with the following functionality in the DIAdem View:
- Append DIAdem View Contour graph
- Append DIAdem View Map
Thanks in advance!
With kind regards,
Stijn
Message 11 of 15
(3,075 Views)
Hello Brad,
Is it also possible to add this feature for a TextBox in the DIAdem VIEW.
Thanks!
Stijn
Message 12 of 15
(3,071 Views)
Hi Stijn,
I've added a section to the script that analyzes the contents of any textbox areas and tries to point them from the original group to the new group.  Let me know if I've anticipated all your formula/reference usage in your text boxes.  If not, please send me a TDV file with a sample content that doesn't work.
Brad Turpin
DIAdem Product Support Engineer
Message 13 of 15
(3,026 Views)
Hello Brad,
Thanks for the adjusted script! It works good with the Textbox in the DIAdem View.
Is it also possible to add this feature to the script for the next Display Types:
- Contour
- 3D Model
- Map
Thanks in advance!
With kind regards,
Stijn
Message 14 of 15
(3,012 Views)
Hi Stijn,
I expanded the script to also adapt VIEW areas of types "Contour" and "Map".
Brad Turpin
Message 15 of 15
(2,962 Views)
