DIAdem
Applying rounding function to entire channel
I have a channel in DIAdem with a large amount of values (36,000,000)  the values contain about 13 decimal places.
I would like to round the value off to about 4 or 5 decimal places max.
Can someone help me figure out how to do this in DIAdem.
Example:
0.3784729837492 ->0.37847
I want do do this for every value in the channel.
can someone help me figure out how to do this?
Thanks in advance,
Tom
(5,531 Views)
Hi Tom,
You can utilize the VBScript function, Round(value, number of decimal places).  I wrote a quick script in DIAdem which performs this operation on a numeric channel, named dataChannel, and transfers the truncated values a new channel, named truncChannel.
Dim toBeTrunc, i
For i = 1 To Data.Root.ChannelGroups(1).Channels("dataChannel").Properties("length").Value
     toBeTrunc = Data.Root.ChannelGroups(1).Channels("dataChannel").Values(i)
     Data.Root.ChannelGroups(1).Channels("truncChannel").Values(i) = Round(toBeTrunc,3)
I hope this helps.
Warm Regards,
Daniel Dorroh
(5,499 Views)
Accepted by topic author TomFerraro
D-cubed's method will work, but with 36,000,000 data points, it will take a long time.  Use the calculator.  Copy this function into the calculator under analysis, and it will occur just about instantaneously.  Replace the 3 with the desired number of decimal places.
Ch("[1]/Channel")=Round(Ch("[1]/ChannelToBeRounded"),3)
If you need a VB Script:
Dim ChannelToRound, DecimalPoints
ChanneltoRound="[1]/ChannelToBeRounded"  'Put the channel you want to round here
DecimalPoints=6             'Specify the number of decimal points
'This will create a new channel called "Channel" in group 1 with the rounded values
Call Calculate("Ch(""[1]/Channel"")=Round(Ch(""" & ChannelToRound & """)," & DecimalPoints & ")",NULL,NULL,"") '... CalculateFormula,CalculateSymbols,CalculateValues,CalculateTargetUnit
(5,490 Views)
Hi RSenior,
Thanks for your post!  Your approach is definitely more efficient.
Daniel Dorroh
(5,473 Views)
Thanks everyone for all your help, I really appreciate it.
(5,466 Views)
