DIAdem
Are different time channels allowed in the same file?
I would like to store several different time channels in the same file. Does Diadem allow this? Basically I have want to associate some numeric channels with a time channel and other numeric channels to a different time channel. But all these numeric and time channels should ideally be in the same file.
(2,777 Views)
Accepted by Twinsen
DIAdem files have group of channels.
So for your approach a nice solution would be to put each time channel with its numeric channels in an own group.
If the time channel is the first one you can drag and drop the group on report and it will show the channels over time.
There is no restriction to mix time and numeric channels in DIAdem.
(2,749 Views)
