DIAdem
Aritmethic average in text numerical operation DIADEM-GRAPH
I suppose this doubt might be posted several times, but I coudn't find it.
How can I set the Arithmetic average value from a entire channel, in the Diadem-Graph and/or Calculation automatically. Also any idea how to do it in VBS-script ?
Diadem 8.1
Thanks in advance
RodrigoSmiley Very Happy
(3,569 Views)
Hi Rodrigo,
You can use the CCH function: CCh(ChannelName,StatValueIndex)
ChannelName Specifies the name of a data channel.
StatValueIndex Specifies the index of the characteristic value to be calculated. Index Characteristic value are:
0 Mean
1 Minimum
2 Maximum
3 Range
4 Sum
VBS syntax:
dblMyResult = CCh("ChannelName",2)
REPORT/GRAPH:
Call GraphObjOpen("Text1")
  TXTTXT = @CCh("ChannelName",2)@
Call GraphObjClose("Text1")
Or set the text content to: @CCh("ChannelName",2)@
Greetings
Walter
(3,559 Views)
Hi Walter
Thanks a lot for your hint.
It was really helpfull.
Regards
Rodrigo (Sao Paulo - BR)
(3,532 Views)
