DIAdem
Error in the script dac driver, Diadem 10
I have recently installed an upgrade to Diadem 10. I am running Diadem 9.1 without problem on my computer.
When I try to run a DAC with a script block inside with Diadem 10 i get an error message, "Error in the scipt DAC driver: Cannot start the script engine. To solve this problem you might have to reinstall Diadem.".
I have tried to reinstall Diadem 10 and I have upgraded it to SP1, but I can't get rid of the problem...  The computer is running with Windows 2000.
Thanks in advance
Robert
(3,373 Views)
Hi Robban,
Some of the default settings have been changed for DIAdem 10. Select Settings>>Options>>General to view or modify the settings in the "Compatibility" dialog box. One of the changes is that NoValues are represented by NaN instead of a substitute value.
Depending on the DAC device driver you are using the new NOVALUE handling may caurse the problem. Please switch of the new NV handling and try again.
Greetings
Walter
(3,349 Views)
Hi Walter,
I tried your proposal, and unfortunately it didn't help... I also tried to set the compatibility reference to version 9.1 but it didn't help either...
Kind regards
Robert
Message Edited by Robban on 11-06-2006 03:11 AM
(3,331 Views)
