DIAdem
ArraytoChannels error "Cannot append, because the target channels are not all the same length"
Hello!
After the end of my second day of try error, i have to bring this quesiton to the table:
I am using ArraytoChannels function to store ADO recordsets as channels. What is strange is that for the first recordset, it works; but for the next time in the loop, it always fails with the error message "Cannot append, because the target channels are not all the same length".
I confirmed that:
the sizes of the RowData and the ChannelNames are equal,
both pass the isarray =true test,
i change the order of the ChannelNames,
i reconnected/disconnected from/to the oConnection each time,  nothing changed.
I am  apparently missing something -but going crazy to figure out what! - if anybody can share his/her opinion I will so much appriciate. Here is my code:
oTables=Array("WellStates","ChokeData","WellParameters", "FlowData","PumpData","SensorsData", "ModelCalculatedData")
 Call OpenSQLConnection
 Set oRecordset = CreateObject("ADODB.Recordset")
 Call SelectWell
 Call GetWellStateIDs
Data.Root.Clear
for j=0 to ubound(oTables,1)
   sSQLSting = "select * from [" & oTables(j) & "] where [WellStateID] between " & WellStateIDFirst & " and " & WellStateIDLast
   oRecordset.Open sSQLSting, oConnection
   Dim oFieldNames : Array : ReDim oFieldNames(orecordset.Fields.count-1)
    for i=0 to orecordset.Fields.count-1
       oFieldNames(i)=orecordset.Fields.item(i).name
    next
   oArray=oRecordset.GetRows(-1,0,oFieldNames)
   Set oGroup=Data.Root.ChannelGroups.Add(oTables(j))
   arraytochannels oArray, oFieldNames
   oRecordset.close
   oConnection.Close
next
sub GetWellStateIDs
  sSQLSting = "select * from [WellStates] where [wellid]=" & WellID
  oArray=oRecordset.GetRows()
  WellStateIDFirst=oArray(0,0)
  WellStateIDLast=oArray(0,ubound(oArray,2))
  oRecordset.close
end sub
sub OpenSQLConnection
  Set WshNetwork = CreateObject("WScript.Network")
  oComputerName = WshNetwork.ComputerName
  oDB="MX2.Player.DB"
  Set oConnection = CreateObject("ADODB.Connection")
  oProvider = "Provider=SQLOLEDB.1;Integrated Security =SSPI;PeoExecuteist Security Info=True;Data Source="
  oProvider = oProvider & oComputerName & "\MX;Use Procedure for Prepare=1;Auto Translate=True;Packet Size=4096;Workstation ID="
  oProvider = oProvider & oComputerName & ";Use Encryption for Data=False;Tag with column collation when possible=False;Initial Catalog="
  oProvider = oProvider & oDB
  oConnection.ConnectionString = oProvider
  oConnection.Open
end sub
(7,282 Views)
The ArrayToChannels method behaves a little currious.
It just takes the channel name into acount not taking looking for group or anything else.
i used an ugly woraround by appending a string at the end of each channel name and removing it at the end.
Dim MyArray(1,10000), MyChannels(1), I
For I = 0 to 10000
  MyArray(0,I)=2*Pi*I/10000
  MyArray(1,I)=Sin(2*Pi*I/10000)
MyChannels(0)="X Channel"
MyChannels(1)="Sin Channel"
const uniqueStr = "______"
Data.Root.Clear
  ogroup.Activate
  dim chList : chList = ArrayToChannels(MyArray, MyChannels)
  dim chRef : for each chRef in chList
    dim chObj : set chObj = data.GetChannels(chRef).Item(1)
    chObj.name = chObj.Name & uniqueStr
next
dim grpObj : for each grpObj in data.Root.ChannelGroups
  dim chOb : for each chOb in grpObj.Channels
    chOb.Name = left(chOb.Name, len(chOb.Name) - len(uniqueStr))
The newly created group also has to be marked as active to be used as target.
Hope you can use this example.
(7,258 Views)
Accepted by KorayKinik
Another hint. If you check the DIAdem help for
Microsoft Windows Script Debugger
you are able to install the debugger in DIAdem.
It would potentially have shown you that the command is not working like expected.
Sorry for the inconveniance
Andreas
(7,252 Views)
Found a better solution. It is possible to put the group names into the names field as channel reference.
So if you just replace
by
  dim newChNames : newChNames = Array()
  redim newChNames(UBound(oFieldNames))
  dim nI : for nI = 0 to Ubound(oFieldNames)
    newChNames(nI) = oGroup.Name & "/" & oFieldNames(nI)
  arraytochannels oArray, newChNames
it should work.
I just append the running example:
Dim oArray(1,10000), oFieldNames(1), I
For I = 0 to 10000
  oArray(0,I)=2*Pi*I/10000
  oArray(1,I)=Sin(2*Pi*I/10000)
oFieldNames(0)="X Channel"
oFieldNames(1)="Sin Channel"
Data.Root.Clear
next
(7,244 Views)
Hi Andreas,
Many thanks for the prompt and detailed explanation - i will try this now and hopefully this time will make it work.
Cheers! 🙂
(7,230 Views)
it worked!
thanks again!
(7,177 Views)
I came here fighting the same error due to a channel I was trying to create in two different groups with the same name. This solution (adding group names) worked perfectly. Just what I needed!
(2,786 Views)
