DIAdem
Arrows on Curves in reports Programmatically
I would like to add some pointers using the arrow on the curves programatically (please refer the attachement)
The Curve peaks would change based on the data; hence I would like to get a report where the arrows are can be put for each point along with the text A0 etc. Though I can locate the peaks on the report am unable to put the arrows.
Can anyone quickly help me on this?Waiting for your earliest response.
TIA
Priya
(4,837 Views)
Hi Priya,
you can use "Curve Coordinates" in a 2D axis system to bind arrows and comments to a point on a curve.
Look for the example "2D Axis System with Curve Coordinates" in the DIAdem help file.
I suggest you prepare a similar layout for your case manually and then change the "Approximation coordinates" with a script to adjust the display to new data.
I hope these hints help you.
DIAdemo
(4,793 Views)
Thank you DIAdemo; will definately check this out.
(4,791 Views)
