DIAdem
How to get out the E+ from the axis in Diadem Report?
Hallo
on the photo you can see numbers written like 10E+5 etc.  Like I have done the 10^5 shall be written in front of the unit and not after the numbers.
The channel is created with Diadem Analysis
Thank You
(4,585 Views)
You can sclae the channel by 10^-5 if you're already considering that portion in the unit. You can do this in a script using the following. Otherwise it's in the basic mathematics portion of Analysis.
Call ChnLinScale("Group/Channel","/LinearScaled",1E-05,0)
Hope that helps!
(4,564 Views)
yes, thank you.
(4,556 Views)
