DIAdem
Auto scaling of tdr layout
I need the tdr layout which was created already with an arbitrary scale should be auto scaled depending on the size of the channels(X and Y).
For example, I had created a tdr format with an simple XY plot with X max scale as 50 and Y max scale as 20 and I have a data with X channel which can go upto 70 units and Y channel which can go upto 50 units. When this channel is called to be plotted in the tdr layout created above, it should automatically resize its scaling to X max as 70 and Y max as 50. Is this possible in diadem?
X. Ignatius
(5,527 Views)
Hi X. Ignatius,
Sure.  The simplest way to handle this would be to set the X and Y axis scaling of that graph to "Completely automatic", then save the TDR file.
Brad Turpin
DIAdem Product Support Engineer
(5,499 Views)
