DIAdem
tdm excel automation
Hey there,
I got a script that creates *.TDM files. The annoying part is that i have to right click everytime on the created file to convert it with the TDM EXCEL ADD INN and save it with the same name like the created *.TDM file.
So, I wanted to implement it in my script but it doesn´t work.
There a piece of code i found here in the Community but in the line which says "oComAddIn.connect = True" occurs an error.
Dim oExcel
Dim oComAddIn
Set oExcel = CreateObject("Excel.Application")
For Each oComAddIn In oExcel.COMAddIns
If oComAddIn.ProgId = "ExcelTDM.TDMAddin"Then
oComAddIn.connect =True
IfNot oComAddIn.Object IsNothingThen' use the object interface here
Else
MsgBox"No object interface available! :-((("
EndIf
EndIf
I´m very thankful for every help.
(6,318 Views)
you do not have to loop over all COMAddIns, simply use the Item() Method for COMAddIns to get the AddIn you want.
The oComAddin.connect = True is only necessarry if called from within Excel.
The following code should work as expected
Dim oExcel
Dim oComAddIn
Dim myBasePath : myBasePath = "C:\data\"
Dim myFilename : myFilename = "MyFilename"
Set oComAddIn = oExcel.Application.COMAddIns.Item("ExcelTDM.TDMAddin")
oComAddIn.Object.ImportFile myBasePath & myFilename & ".tdm"
oExcel.Application.Workbooks(1).SaveAs myBasePath & myFilename & ".xlsx"
Hope this helps
(6,314 Views)
Hey,
thank you very very much. It works but it occured another problem.
I try to open the file and it opens itself twice. One file has no name, the other file has the desired name but it is in the read only mode.
When i try to delete all it´s not possible because Windows thinks it has acces to this new file.
Can you help me in this case again?
(6,307 Views)
Accepted by topic author Dredg042
After running the script, please take a look into the task manager of Windows. Is Excel still running?
If yes, the following lines should close Excel at the end of the script:
oExcel.Application.Quit
Set oComAddIn = Nothing
Set oExcel = Nothing
(6,303 Views)
Thank you sooo much!!!!
(6,299 Views)
