DIAdem
Automatic update of DAC-DataExport signalnames and terminalnames from DAC-Sublayers
i am working with Diadem 2012  on a Win7 64bit computer.
I am able to change the signalnames of a scale-block in my DAC-Diagramm using a userdialog. That works fine, but
when i open the dataexport from my DAC-sublayer for the first time, where i use automatic terminalnames i can see that the Signalname and the terminalname are not the
same.
Opening this dataexportport for the second time, shows corresponding signalname and terminalname.
That is why i would like to ask you if there is a possibility to automatically update all dataexport-/dataimportports at one time out of a script or dialog.
I am using a german version of Diadem an i am not sure if the words signalname, terminalname, dataexportport and DAC-Sublayer a translated correctly, i am sorry for that.
With kind regards
ingo
(5,512 Views)
Hi Ingo,
Unfortunately is this not possible. There is no command of function which copies the names to the subblock.
Greetings
Walter
(5,469 Views)
