DIAdem
change line color in 3D diagram with points - e3DShapePoints
How can I change the line color in a e3DShapePoints diagram type? I want to use one of the predefined global palettes.
I managed to switch the marker line color via:
Report.Sheets.Item(MySheetName).Objects.Item(MyDiagramName).Curves3D.Item(MyCurveName).Shape.Settings.Marker.Line.Color.ColorIndex = eColorIndexGlobalColorPalette3
but this will not enable the color legend unfortunately. Apparently there is no line object available in the curve settings.
Any suggestions?
Message 1 of 11
(7,970 Views)
Hi Phex,
The "e3DShapePoints" 3D curve type you have chosen is for marker-only display.  There is no way to engage a line to be drawn with this curve type.  If you choose the color for this curve to be one of the global palettes, though, you will be able to display the color legend.  But if you want to see lines, you'll have to choose a different curve type.  Can you describe or post a picture of what sort of lines you want to see?
Brad Turpin
DIAdem Product Support Engineer
Message 2 of 11
(7,640 Views)
Hi Brad,
I do not want to connect the markers with lines. The picture shows what I want to produce:
legend
The problem is that I cannot access the line color object to change it from standard "red" to "global palette 3". This only works manually via the dialogue box.
Is there any possibility to change the line color via script?
/Phex
Message 3 of 11
(7,636 Views)
Hi Phex,
use the following example:
Dim oMy3DAxisSystem, oMy3DCurve, oMyPos, oMyShape
Call Report.NewLayout()
Call Data.Root.Clear()
Call DataFileLoad(DataReadPath & "Report_Data.tdm","TDM","")
Set oMy3DAxisSystem = Report.ActiveSheet.Objects.Add(eReportObject3DAxisSystem,"My3DAxisSystem")
Set oMyPos = oMy3DAxisSystem.Position.ByCoordinate
oMyPos.X1 = 20
oMyPos.X2 = 80
oMyPos.Y1 = 20
oMyPos.Y2 = 80
Set oMy3DCurve = oMy3DAxisSystem.Curves3D.Add(e3DShapePoints, "MyNew3DCurve")
Set oMyShape = oMy3DCurve.Shape
oMyShape.DataStructure = e3DDataStructureMatrix
oMyShape.XChannel.Reference = "[2]/[1]"
oMyShape.YChannel.Reference = "[2]/[2]"
oMyShape.ZChannel.Reference = "[2]/[3]"
oMyShape.Settings.Marker.Type = eMarkerCircle
oMyShape.Settings.Marker.Filling.UseCurveColor = False
Call oMyShape.Settings.Marker.Filling.SetPredefinedColor(ePredefinedColorred)
oMyShape.Settings.Marker.Line.UseCurveColor = False
oMyShape.Settings.Marker.Line.Color.ColorIndex = eColorIndexGreen
oMyShape.Settings.Marker.Filling.ColorIndex = eColorIndexblack
Call Report.Refresh()
The folowing set the color of the marker.
This is very similar to any other diagramm: you have a line and a marker. Like Brad has sayed, these diagramm doesn`t draw any linesso you have to recolor the marker.
Kind Regards,
Philipp K.
AE | NI Germany
Message 4 of 11
(7,602 Views)
Hi Philipp and thanks for your reply. Unfortunately it does not adress my problem.
I modified your code only by setting the UseCurveColor parameter to "TRUE":
oMyPos.X1 = 20
oMyPos.X2 = 80
oMyPos.Y1 = 20
oMyPos.Y2 = 80
oMyShape.Settings.Marker.Filling.UseCurveColor = True
oMyShape.Settings.Marker.Line.UseCurveColor = True
Now you see all points in red, because the standard curve color is red. In order to change that I need to go manually into the Curve Properties and change the display color to "Global Palette 3", because this is what I want to see. So how can I achieve this by scripting?
/Phex
Message 5 of 11
(7,599 Views)
Hi Phex,
I think I haven't get your problem.
When you go to th DIAdem help (Programmierreferenz > Objektorientierte Script-Schnittstellen > DIAdem-REPORT > Eigenschaften > Eigenschaft: ColorIndex für Color) you find the explanation of the property ColorIndex. It's an enum with the folowing entries:
Bestimmt die Farbe.
Aufzählung mit Schreib-/Lesezugriff und folgenden Auswahlbegriffen:
0
eColorIndexNone
Keine
1
eColorIndexBlack
Schwarz
2
eColorIndexRed
Rot
3
eColorIndexGreen
Grün
4
eColorIndexBlue
Blau
5
eColorIndexViolet
Violett
6
eColorIndexTurquoise
Türkis
7
eColorIndexGrey
Grau
8
eColorIndexYellow
Gelb
9
eColorIndexDarkRed
Dunkel-rot
10
eColorIndexDarkGreen
Dunkel-grün
11
eColorIndexDarkBlue
Dunkel-blau
12
eColorIndexDarkViolet
Dunkel-violett
13
eColorIndexDarkTurquoise
Dunkel-türkis
14
eColorIndexDarkGrey
Dunkel-grau
15
eColorIndexDarkYellow
Dunkel-gelb
16
eColorIndexWhite
Weiß
17
eColorIndexOtherColors
Andere Farben
18
eColorIndexPalette
Palette
19
eColorIndexGlobalColorPalette1
Globale Palette 1
20
eColorIndexGlobalColorPalette2
Globale Palette 2
21
Globale Palette 3
22
eColorIndexFillEffects
Fülleffekte
When you change the value eColorIndexGreen to eColorIndexGlobalColorPalette3 you have choosen the global palette 3.
Kind Regards,
Philipp K.
AE | NI-Germany
Message 6 of 11
(7,584 Views)
Yes you are right, I could change UseCurveColor back to "FALSE" and replace eColorIndexGreen with eColorIndexGlobalColorPalette3, but then I do not get my color legend. In order to achieve that I need to change the display color of the curve to eColorIndexGlobalColorPalette3, but obviously there is no object prepared for that or did I miss it...?
Message 7 of 11
(7,582 Views)
Could anyone reproduce what I am trying to achieve ?
I would need to change the display color to "eColorIndexGlobalColorPalette3" in order to enable the color legend. How can I do that by script ?
Message 8 of 11
(7,476 Views)
Accepted by topic author Phex
If you cange the color in the curve definition dialog for "points" this corresponds to the textcolor of the "points" because no line is available. (oMyShape.Extensions.Label.Font.Color.ColorIndex =eColorIndexGlobalColorPalette1)
oMyPos.X1 = 20
oMyPos.X2 = 80
oMyPos.Y1 = 20
oMyPos.Y2 = 80
'oMyShape.Settings.Marker.Line.UseCurveColor = True
'oMyShape.Settings.Marker.Line.Color.ColorIndex = eColorIndexGreen
'oMyShape.Settings.Marker.Filling.UseCurveColor = True
'oMyShape.Settings.Marker.Filling.ColorIndex = eColorIndexblack
oMy3DAxisSystem.ColorLegend.Visible = True
This is a little bit confusing.
Hope this helps
Winfried
Message 9 of 11
(7,470 Views)
Awesome! Thank you so much, that solved it.
/Phex
Message 10 of 11
(7,467 Views)
