DIAdem
Change Lines in waterfall diagram
In a waterfall diagramm each signal is consisting of two lines: The "real" signal line and a straight line (which i marked red). Is it possible to delete or to hide these straight lines?
I already know the variable "D3CurveHidden", which changes the area between two lines. But it is not the solution of my problem.
(6,260 Views)
Hi there,
it's not possible to delete these lines. But you can "hide" them when you change the view angle of your diagram.
For example:
( see Attachment; Can't insert pics directly 😕 )
Note: These charts contain all the same data, only the angle of view has changed!
Hope this could help you.
Branni
(6,206 Views)
Hi Tretetder,
Here's another approach to try.  Select the 3D curve type "Surface", but then click that curve's [...] button in the 3D graph configuration dialog to pop up the "Curve Parameters: Surface" dialog.  There check the checkbox "Surface lines parallel to x- axis".  This results in a 3D graph that looks a lot like what I think you want.
Brad Turpin
DIAdem Product Support Engineer
(6,190 Views)
Thank you, Brad-turpin
I was looking for that.
(6,105 Views)
