DIAdem
Automatize of time chanel generation
Hi KrzyFul2,
It seems that in DIAdem 2012 sometimes the "for each " doesn't assign the channel object (aChnl) correct.
I fixed this with the command ChnCharacter(). And I saw that the quotation marks in Find and FindReverse were uncomplete.
dim dLimit, iStartPos, iStopPos, aChnl, aGroup
For Each aGRoup In Data.Root.ChannelGroups
  For Each aChnl In aGroup.Channels
    call ChnCharacter(aChnl)
    R1        = aChnl.Properties("maximum").Value * 0.05
    iStartPos = find("ch(""" & aChnl.GetReference(ExtendChnName) & """) > R1")
    iStopPos  = FindReverse("ch(""" & aChnl.GetReference(ExtendChnName) & """) > R1" )
    call DataBlDel(aChnl.GetReference(ExtendChnName), 1, iStartPos)
    aChnl.Properties("length").Value = iStopPos - iStartPos
    Call aChnl.Properties.Add("To_Process", "Yes", DataTypeString)
Please keep in mind, that the command ChnCharacter takes a bit time. I tested this code without ChnCaracter in DIAdem 2018 without problems. So ChnCharacter is only a workaround as long as you work with 2012.
Greetings
Walter
Message 11 of 11
(271 Views)
