DIAdem
BUG REPORT - Cannot find specified text. when running a script by pressing SHIFT+F3
Thanks for the additional info. After some research I found out the following:
This behavior is definitely preset in DIAdem 2014 I was able to reproduce it. It is no longer preset in 2015 (was reported and fixed). I have no info about that there will be a fix for 2014 - this is not a critical nor a security issue. Sorry for that. You can upgrade to 2015, or don't use this shortcut, or run this script assigned to F3 via mouse click on Diadem Scripts (Start with...) on panel specific functions.
B/R
Jozef Lipták
Message 11 of 12
(1,652 Views)
Ok thansk for info, i can deal with it and im not using the 3rd script shortcut no more. I stick with the 2014 version as its way faster in writing script then the 2015 which cause me lags when editing scripts, as i reported in other thread of this forum.
I didnt found out how to mark this thread as resolved, so please mark it if you are able to.
Message 12 of 12
(1,648 Views)
