DIAdem
Bar graph with error bars
Has this changed in Diadem 2011?
I used to be able to achieve this (a bar graph with positive error bars) by creating a Line plot, setting the error bars, and then changing to a Bar plot.  Now the error bars are deleted.  Seeing as it did work previously, a better change would have been to allow the creation of error bars as part of a Bar plot.
The workaround is to create an additional Line plot with no line, just error bars.
(4,082 Views)
Hi GregS,
The process that you were using previously was unexpected behaviour. That has been caught and fixed. The process that you are currently using is the right way to do it from now on. I hope that this helps.
Perry S.
(4,059 Views)
Sometimes "unexpected" is convenient!  Smiley Happy  My problem with the "fixed, correct" way is that I now need two plots to show a single entity.  Oh well, the price of progress...
(4,054 Views)
