DIAdem
Bus Log Converter Using with .csv file
Normally I use .log files that are logged by Kvaser. However, in this case I have .csv file and I cannot use it with Diadem Bus Log Converter. Also I cannot convert it to .log file. Is there any solution about it.
My all files are logged by Kvaser but export file extension is different such as .log file and .csv file. I am trying to resolve by using Bus Log Converter. If I convert my .csv file to .log file or if I can use .csv file with Bus Log Converter, it would be great.
Thank you for your help.
Mehmet
(2,326 Views)
Did you try "Kvaser ASCII"?
(2,284 Views)
Unfortunatelly, it did not work.
"Bus Log Converter Error: Cannot create TDM file with the extented settings. Refer to the DIAdem logfile for mor information."
By the way, I use DIAdem 2020.
(2,242 Views)
