DIAdem
REPORT: bug in internal script by canceling dialogs of report-objects
i got and error reported by user. When we click the limit curve description, dialog opens and clicking the X toprightcorner to cancel dialog triggers this error. Even when we click and cancel the legend dialog.
The bug is doing one more thing: it sets some integer value to X reference of curves. As we use waveforms, we keep the X axis empty, but this bug sets some unknown number, and then it makes our waveforms curves not displayed, and users have to manually delete the strange number in X reference and keeps just the Y reference to the channel we want to display.
Do you have a solution to erase this problem? Thanks
(1,380 Views)
Hi Lukas_Doubek,
I have tried to reproduce this problem, but it seems to work fine on my side. I have tested it with DIAdem 2020 SP1.
Which version do you use?
Can you provide the layout for tests?
Greetings
Walter
(1,345 Views)
