DIAdem
Bus log converter error: Cannot create TDM file with extended settings
Good day,
I need to convert *.blf files, acquired using CAN Analyze, using BUS Log converter on DIAdem 2017.
See the atached data below:
CAN dbc: PCAN-Power.dbc
DIAdem Bus log config file: Config.tcc
Vector CAN Analyze file: express 26.04.23_ctv31_T007.blf
Thanks in advance
(1,226 Views)
Hi Rafael_Raider,
I have made some tests with DIAdem 2023 Q2 and could import your blf file.
I have added the bus type to the defintion, the ID Mode was set to Default, and under Advanced Settings both opotions were enabled.
Please try it with my config file as well and check if this solves the issue. Normally, the defintion settings are the root cause for your error.
The result and MyConfig.TCC files are attached to this post.
(1,194 Views)
Hi ColinF
First of all, thank you for the quick response.
I've loaded the "My_Config.TCC" that you sent and created the exactly file path on my desktop, to prevent any issues.
Even so, I am getting the error. Please see the image below:
(1,184 Views)
Hi Rafael_Raider,
as I see the error has changed. This looks for me like the settings for the import are somehow okay, but the import still hangs because of something else, eventually related to data portal.
I would check the following points:
  • Does the DIAdem logfile include something interesting?
  • Delete the internal data from data portal before starting the BLC
  • Select for "file import" the option "Create TDM file only"
(1,152 Views)
Hi Rafael_Raider,
if this does not help I recommend a newer version of DIAdem according to the following NI KB: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Q4uSAE&l=de-DE
This could explain why my import works and yours still shows an error, because of your DIAdem 2017.
(1,149 Views)
